jaylectricity
- Massachusetts
- licensed journeyman electrician
Today, using my screwdriver I poked through the small hole in the tile where the wire for the vanity light poked through to see if I should cut a hole for an oldwork box or use a pancake box. I felt a stud right on center of where the light bar would go. So I cut the hole for the pancake box only to find out that it was actually the PVC vent pipe that I was feeling.
What I ended up doing was making up the splice in the pancake box, attaching it to the back plate of the fixture with the 8-32 machine screws. Then I mounted the back plate of the fixture to the tile using wall anchors and screws through the factory cut mounting holes towards each end of the light bar.
There is no gap between the junction box and the fixture, everything is bonded, the box is securely attached to the fixture and the fixture is securely attached to the wall. But technically the box itself is not screwed into any of the building finish. Is this a violation of any code?
