I wouldn't consider a mirror installed as you describe 'part of the building'.314.29 Boxes, Conduit Bodies, and Handhole Enclosures to Be Accessible.
Boxes, conduit bodies, and handhole enclosures shall be installed so that the wiring contained in them can be rendered accessible without removing any part of the building or, in underground circuits, without excavating sidewalks, paving, earth, or other substance that is to be used to establish the finished grade.
Is a junction box installed behind a mirror which is secured by screws and clips a Code violation ?
If it's a framed mirror and hangs with wire or clips then no problem. If it requires tools then i say you covered it and it gets tagged.
	Like Al, I don't like the idea, but it would be easier to get to than one half way under a house or in an attic I guess, but who would know it's there?
I may have to think about this one more.:-?
This same tool is often used to find ones buried in sheet rock or plaster.... Likewise, I often use a screw-driver to find boxes in plaster - just poking it through - sometimes just willy nilly out of spite....Jim, even if it only takes one tool to access the j-box it gets tagged?
Bad idea. Violation-I dunno.Is a junction box installed behind a mirror which is secured by screws and clips a Code violation ?
I agree. One would expect to find a j-box in an attic or a crawl even if it were hard to get to. But behind a mirror????I don't like the idea, but it would be easier to get to than one half way under a house or in an attic I guess, but who would know it's there?
If the box is burried behind the cabinet I no like for the same reason as the mirror, however, in this case the box could be blanked inside the cabinet.what about a box behind an upper kitchen cabinet that can be dropped by removing four or so screws?
Dont know about others but i would not remove a mirror that is screwed in place, maybe a cabinet. And key word is REMOVE.
................... But then if the homeowner screws a mirror over a box in the bedroom, is he committing a violation by covering a box? Is that "finish" or an embellishment, like a picture?.................
No, the key word is "part of the building"
Taking down a mirror would not be considered "removing part of the building" nor should it be.
No violation and no big deal in my view.
Accessible (as applied to wiring methods). Capable of
being removed or exposed without damaging the building
structure or finish or not permanently closed in by the struc-
ture or finish of the building.
