There seems to be a lot of confusion with this question due to most people have not done this wiring method. And how they interped the codes on this
on a 3 phase system can you run the same phase wires in parallel in the same nomatallic conduit, example: 4 (A) phase wires in conduit (1) 4 (B) phase in conduit (2) and so on.
second part of question, the code states that it hase to terminated at an overcurrent devise, if I'm going into a tap box going to switch gear with main overcurrent device is this the same.
