jmshiller
 - Marco Island
I was wondering if a 15 amp dedicated circuit is allowed for a 11.5 amp microwave. I can't find a code reference that requires a 20 amp. This is a remodel with a conduit that will only allow a 14/2 romex.
Even withstart up current , if there is any, I seriously doubt the breaker would be an issue.I agree with John. The only thing I would be concerned with is the start-up current of the unit. If it's a counter-top unit you're probably OK. If it's an under-cab unit the start-up currents can sometimes run up over 20 amps.
Unless the instructions state that a 20 amp circuit is required.
Because they're packed inside the unit.The simple thing is just to read the instuctions from the manufacturer.
I often wonder why people never want to open that little book labeled installation instructions.![]()
I read instructions . . . sometimes.I often wonder why people never want to open that little book labeled installation instructions.![]()
I also eat quiche.![]()
All micros I've instaled required a 20 amp ckt.
I can't recall ever seeing a residential micro with a 20 amp cord cap .. not saying they are not out there ,.just that they are very uncommon where I live and work .
You know that answer. art. 210.21(B)so if they call for a dedicated (whatever that is) 20 amp branch circuit and the unit has a 15 amp attachment plug can I use a single 15 amp receptacle ,.. so that it remains a dedicated circuit???
. There is no reason to second quess the manufacturer's instructions the simple thing is just to follow them. .
