Some food for thought tonight..........
Wondering how different folks handle the installation of circuits for HVAC condenser units on mobile homes.
A number of the mobile homes I've inspected lately have a factory installed empty PVC into the home panel.
E/Cs have used this to wire the condenser unit. The practice opens a number of questions in my mind.
(a) Since the mobile homes are a pre-wired HUD unit, is it legal to add a circuit to the interior panel ?
(b) If you can add a circuit, would the requirement of 550.20(B) prevent you from wiring the condenser this way.
and a related question:
(c) Can NM be installed under a mobile home if properly supported and following a building surface ?
(d) If NM, UF, or any cable is installed under the mobile home, would the use of the factory stub violate 312.5(C) ?
