- Massachusetts
Well i don't think you understand this but its a factory screw up on the label only and cover plate so we get a letter from the CH factory which covers us in the engineer part of this issue.
They would have to come out and change the breaker or label but electrically its fine its just not your normal way you see a breaker in a panel .
Ohm, I work on equipment like this as well. I fully understand.
I think your position is that 'This is what we do and it passes so it must be OK'.
It is not OK, it is a violation.
We will not touch there stuff its a ul thing
Exactly, and with line and load mislabeled you are in violation of this 'UL thing'
Since they write the white pages its ok
No, it is not OK, they can not change the requirements.
