mkgrady
- Massachusetts
I find that new surface mount ceiling fixtures require that the branch circuit wires be rated 90 degrees. Of course the older homes do not meet this requirement. I see this instruction on many, if not all of the surface fixtures that have the fiberglass insulation between the canopy and the ceiling. Presumably the fiberglass is there to keep the wires in the outlet box from getting hot. Or maybe it's there to keep heat from escaping into the attic.
I realize one work around is to put a JB in the attic and run to the light outlet box with new wire but we don't always have an attic.
Considering this, are there fixtures made to alleviate this incompatability? I would think a fixture could be made that does not heat up the BC wires. I don't think it would be the type described above but there must be some choices.
