texashangman3
what causes 120 volt single pole switch to read 18 volts with the switch off
what are you measuring ? (Load side of switch to neutral, Load to ground, etc)
and what type meter are you using ?
checking load side with digital meter
Something sounds wrong here. If there is a working load such as a light bulb on this load side of switch it should kill any stray voltages. That is assuming with switch on the load works.
Yes agreed if it is one. We have not been told it is anything other than normal switch. We need a lot more info for this one.Illuminated switch.
