jaylectricity
- Massachusetts
- licensed journeyman electrician
I found this on another website and thought I would share:
:grin:
:grin:
This is the close-up. What you can't see is the pile of bodies on the ground.I feel sorry for the guy who tries to steal the pliers.
"Seven . . . seven . . . seven . . . " ;)[/QUOTE said:Eight.....eight.....eight.....
That's an old joke but still funny.
I agree that this pic looks "staged". There are no signs of weathering on the vise grips, surely the rain/snow would have them looking pretty bad in very short order if this was a "real" installation.
"Seven . . . seven . . . seven . . . "![]()
Yes, You can tell it is not only staged, but probably stolen from another application. The photo was lit from below to reduce shadow. The reason why I suspect it was stolen is because it is professionally lit. It is a studio picture lit from several different angles.My gut feeling is that this picture was staged.
Chris
It's photoshopped. I've can tell by some of the pixels.
Care to elaborate? I can't see any artifacts, only that it's been saved as a lossy file.
I think it is a staged photo not photoshopped.It's photoshopped. I've can tell by some of the pixels.
No, the lack of shadows indicates that it was lit from many directions. The primary light is coming from below, but either it is using a gel or is a halogen light. There is a moderate light source (possibly external flash attachment) just above and to the right of the lens (yes, the glint on conduit, but also the only shadow that exists). It is also lit with a diffused light from the far right, and I suspect also from the far left, probably from a soft box or a bounce.The shadows suggest it was lit from above. The glint on the conduit suggests a flash. It was probably taken with a flash mounted several inches above the camera (like wedding photographers use to eliminate red-eye). The lighting also suggests that the flash was metered. (Speedlite) This can be done with an over the counter flash, but you are looking at 500 bucks or better.
It does look staged, anyone could have taken the pic but it was probably shot with a high end camera.
CSI - Holt.
