And roger,
I am not talking about fire rated assemblies or fire rated partitions, I am talking about a true, real firewall.  It is free standing and separates buildings essentially making them 2 separate entities.  This is often used to comply with the height and area limitations of the building code, sprinklered building or not.  HVAC ducts will not penetrate these walls.  If they do then you are probably thinking about a fire rated assembly or partition, not a true firewall.
The roll down fire doors that are tied into the NFPA 72 system and have a backup fuse-able link are UL rated along with the doors that are spec'd for installation.
