hardworker
A 100amp sub-panel was installed coming from a 100amp service panel. #3 was used for the 2 hots and the neutral. A neutral lug kit was installed on the neutral bar of the service panel. This kit was a Homeline HOM70AN. The lug from this kit is the type that does not lay on the bar. It has two prongs that insert into the neutral bar and are secured with two wire binding screws. The #3 inserted easily into the kit and is secured. I believe the "70" within the HOM70AN represents 70 amp capacity, but I am not sure. I know the HOM100AN lays on the bar.
Is this lug within code for this application?
