Anyway I wired up a test board with 2 GFCIs in series and it works fine. I kinda answered my first question there. But, what has changed? Why does this work now? All 3 of us are curious and would of bet against this working.
I am not a mod but I don't think you are out of line but I do think you are incorrect.Mods; I'm new here. If I'm out of line please point me in the right direction.
We failed an inspection on a kitchen remodel once when one of my guys inadvertently installed a GFI recep on the load side of another. The inspector said it wouldn't work properly. It sounded like hogwash to me but we changed it anyway.
That's when you ask the inspector for a code reference.
Chris
Just recently, in a commercial setting, we had some trouble with a GFI fed from the load of another GFI. One was installed at a break area counter top and then fed another outlet in a nearby bathroom. We use a fairly common brand of 15A GFI receptacle. Upon initial power up of the building we couldn't get either GFI to reset. We removed the second GFI and replaced it with a standard receptacle and all was right again.
Why did you use another device on the same circuit?
