Hi there,
We have a metal equipment rack in a project, full of AV gear. It's a Middle Atlantic for anyone familiar. This house producs a tremendous amount of static electricity (dry air, thick carpet), and we are starting to see problems with the operation of the equipment when someone walks across the carpet and touches the equipment, as a static shock is discharged.
Is there any way to bolster the ground and direct this static energy away from the equipment with the exiating wiring?
Right now, all the equipment plugs into a surge supressor, that is plugged into a dedicated 15amp duplex.
There is no way to add a ground rod, or tap a cold water pipe.
Thanks for any input. If I know it can be done, i'll call an eletcrician.
