mivey
That would be the best bet if you are curious (I probably would just because I'm like that). Too many possibilities otherwise.Check it for voltage. If there is none, hook up a tone set (fox and hound) and try to find the other end of it. Where the other end is, or isn't, should give you a huge clue.
