- Lockport, IL
- Retired Electrical Engineer
So there cannot exist such a thing as a battery, since it is alleged to have a voltage between its two terminals, even when it sits unpurchased on a store shelf, and since current cannot be flowing in such a situation? :-?Anyhow, I think there is a similar flaw in your model: If you have a wire, you can't have a voltage between the two ends without current flow in the wire. That wouldn't satisify ohms law, since the wire has a finite resistance. Zero current through X ohms must equal 0 volts.
The math error in your logic is that, absent a complete circuit the resistance between the wire terminals (which essentially constitute a voltage source at that point) is infinite. Zero current through infinite ohms need not result in zero volts.
