ohmhead
- ORLANDO FLA
Well if one looks at a electrical coupling inside its made for wire pulling it has a smooth ridge  it does not connect like a plumbing fitting  if one looks at a plumbing coupling its has  a square centered ridge its seals better when glued it mates or has more contact with pipe ends   .
And most electrical pvc couplings are not long enough from center to outside end they dont give us enough internal contact to me there short and weak if they made pvc couplings longer that would be a bigg advantage in the field .
Dont get me wrong your input on this subject is ok your fine we are just pointing out that different areas of electrical are not the same as others we all have issues and minor steps to do our work .
Take care i only hope a pvc VP might come on and give some input or visit our job site hes more than welcome during our string installing ?
