stickboy1375
- Litchfield, CT
pass, see it all the time.
Why is it that the three guys here from New England don't see the problem with this?![]()
FAILED
#1 is 110.26
#2 no staples
#3 OSB board on concrete block. It needs to be treated wood
#4 depends on ahj as to protection of the wires
By not failing it you are sending a clear message that you not enforcing the code. This is why your seeing so much garbage work and if i was working there i would be upset because my price would been to do the job right. I can't bid aginst that kind of work
Make it fourWhy is it that the three guys here from New England don't see the problem with this?![]()
The OSB board is rated for 30 days of moisture
Pierre,
I don''t disagree with you, but would like to enter another thought. I've
inspected for a number of years, some of that time in a municipality with strict enforcement and strict licensing requirements. I've also inspected in rural areas where licensing was lenient and "homeowner" wiring is allowed. I think to some degree the inspector has to adapt to the environment and perhaps wear the "training hat" also.
If I used the same enforcement techniques in the "unlicensed" areas as I did in the City I would have a 90% rejection rate and limited employment.
I have had to prioritize on your #1 point "is it safe". Beyond that I have found it necessary to point out Code violations that are consistent for the area and caution that those are not going to be acceptable. Over time, the quality improves.
I'm not advocating my approach or saying it's "better" it's just different by necessity...I have had to adopt an approach somewhat like a "warning ticket".
But....
Because enforcing the code will produce 90% failure rate is not a good reason to not enforce the code.
Also limiting ones income or job by enforcing the code is a sad statement as to the direction this industry has been moving. I see this happening in many locations and is one of the reasons I left the inspection industry. Competing against inspectors who make inspections from their livingroom, or drive bys, or going to the job and passing it to keep working is a slap in the face to this industry.
Pierre,
augie47 said:I somewhat agree, but I have been the name in that quote and it can be embarrassing. If you elect to make that decision (not to enforce something) you better be prepared to show why you think your preference outweighs that of a Code Panel.
I've inspected long enough to adopt an attitude that if you and I can find justification, great. If not, follow the book.
When its black & white in the book, I can't see any excuse to accept any violation.
They wouldn't bother to look at something like thisJoe Ross, Mark Hilbert, and James Rogers would not pass this, and they are all New Englanders.![]()
Gus, I am not trying to pick on you but your view here is inconsistent with another current thread. I guess it shows the difficulty that we all face outside of the forum. Of course I am not rerferring the the guys that work in a perfect world but those of us that work and inspect in the real world.
They wouldn't bother to look at something like this![]()
The perfect or real world being brought up here is just a smoke screen that some are hiding behind. Of course this is simply my opinion.
I do not see how hard or difficult or expensive or real world it is to not perform or install to some of the easiest requirements we see in the NEC. If it is really that difficult, there are easier jobs...that pay less of course.
fail!!!!!!fail!!!!!!!
no romex!!!!
wouldnt pass at all in chicago
The op's pic shows a violation for sure. It is one of those accepted violations in this area and I have no problem with it.
Question do the inspectors in your area require securing any type of cable or raceway system or any electrical equipment? Where do they draw the line?
