I know I dont have any pictures of the service but these are the facts. I have a meter base mounted on the exterior of a dwelling single family, I came out of the side of the meter base with a 2 " LB extends up 3 ft . This is just a sleeve for my SEU cable from where it breaks the plane of the ceiling under house to the bottom of my panel is 57 " . My inspector and his
posse in the county I live say ,that you have to count the number of inches inside the panel also to comply with the so called 5 ft rule. art 230.70 says nearest readily accessible location. Please note this house is built on columns. The inspector also says that if I come out of my meter base and run up the exterior of the house more than 5 ft I need a disconnect also this is totally nuts and not sure if I should go for the disconnect and SER cable or try to fight them on this. Any help with this one ?
