I will explain this to HO. They don't want me run a new circuit. They would rather have the heater and not jacuzzi. Maybe I can put a switch, to from heater to jacuzzi. The circuit for the light/fan wouldn't be effected, so if they want the jacuzzi they can flip a switch. This would be easy to do. What do you think?
gus
You can put a vent/light directly over a shower on a gfci breaker...but NEVER a heat/vent/light. Call any of the manufactures and they will tell you the same thing..(broan,nutone,panasonic)
The day you start letting the customer dictate HOW you are going to do a job is the day you should hang up your tool belt.
I agree but it does cost a lot more-- I think it is well worth it esp. since there is little to no maintenance on it.
my question is why do you want a heater over a shower? can't afford hot water?
the heater is nice to stand under after exiting the shower after you come out of the hot water and maybe you get a chill then.
