love9099
- Salt Lake City
What I meant
What I meant
I am all for smoke detectors rather than Heats, heats have their place in certain areas and under certain conditions. I appreciate your references. I personally have smokes in all the bedrooms in my home (120v) and in the hallways and yet I also tied smokes to my security system up and down stairs that dial out in case of smoke. Obviously that is not code or mandated that I do such but I did it to protect my family. My whole point is it seemed like someone felt we should put heats in at all the dryer locations and personally I don't think that would alert or wake anyone up but having a decent system with smoke detection in their proper places would. Thank you for your comments.
What I meant
Actually his point is valid.
A rate of rise Heat detector has a response curve. This slows an alarm. In fact a slow smoldering fire will take a LOT longer to be detected with just a heat. (could minutes and that make a HUGE difference in a residential fire developing) With a fixed temp the same delay exists only the alarm point is fixed.
This is why it is not a life safety device and should not be relied upon for fire dectection alone. And again, line voltage smoke and heat manufacturers instructions (kidde, Firex) prohibit the installation of a heat or smoke near washers (Firex manual SPECIFICALLY states not within 10 feet of a washer) http://www.firexsafety.com/NR/rdonlyres/62CD89DB-EC4A-41E0-9DBE-1CD351E80F27/0/110609FEnglish5700.pdf.
In no way do I think smokes should be done away with, I doubt that guy does either, but lets not assume:
Love9099 what did you mean?
