Volta
- Columbus, Ohio
GAR
these are great little teaching tool KEEP THEM COMING apprentices (and others) love hands on things to learn. Science, ohms law, meter use, all wrapped up in one![]()
Yup, I'll second that.
GAR
Interesting. So as this is a closed loop, do we need to consider that there are precisely zero volts present in the system now (no matter how the current was initially injected)?
This circuit seems short.My simple mind at least needs to assume that voltage was present to start this flow.
Do you know who is running this experiment?
So the persistant current is / can be AC?. . . An external power supply is connected to the two wires. Voltage gets applied, which causes the current to ramp up; while the current is changing you still need to overcome the inductance of the wire. After the current is stable at the desired temperature, the heater is turned off and the short length of wire starts to superconduct, closing the loop.
-Jon
I was, and I thought it was clear.I know you were joking, but my suggested experiment was not very clear.
"And, for next week's show, boys and girls, we'll feed amplified music into one bulb, connect the other one to a second amplifier, and send sound across space with light waves."Actually I can take a second 250 W flood and point it at the one of which I am measuring and see the resistance change.
The persistent current itself is DC. But with zero resistance and a very large inductance, you need to think in terms of extremely low frequency AC for the ramp up. The power supply voltage and the rate that the current ramps up is calculated using the inductance of the coil, and my understanding is that this can take hours or days.So the persistant current is / can be AC?
