I am trying to understand completely how a brake resistor on a VFD works.  I know that when the DC bus level gets to a certain level the chopper circuit will turn on and dump the excess energy across the resistor.
Must every drive have this chopper circuit to dump this excess energy across the resistor? In other words, is there ever a situation where the drive is continuously connected to the resistor dumping energy across it? I was always under the impression that the resistor only came on when the Bus DC voltage reached a certain threshold.
Also when the resistor is turned on, does the excess energy actually help slow down the motor and load, or does it simply just provide a means for dumping the excess energy? I've heard the term brake used as if it was actually slowing the motor.
So if a drive has a 3min ramp down time and the DC bus voltage never exceeds its threshold, then will the brake resistor ever have any effect on slowing the motor or dumping the excess voltage?
