Electron_Sam78
- Palm Bay, FL
What are some good methods for bending 2" or 3" PVC  once it's been heated? I have no shoes or spindles
			I've done a few bends using the gloved hand method and used a piece of solid wire as protractor. It can easily turn into a kink. I've heard that plumbers sometimes use sand in copper pipes to keep the internal diameter in tact...
Heat the pipe and lay it up against a factory elbow and then cool it with a wet towel while holding in place
