Drilling I-Beams and bar joists ?
I hear people say it will weaken the structure .All the time I've been in the trade we were allowed unless it had a fireproofing sprayed on it . Our carpenter at work is questioning this . I wanted to see what other people had to say ...
The building codes have a limit as to the size of holes and the placement.
As far as I know there are no restrictions on standdard holes for mounting equipment.
A powder actuated fastener would be much faster. Otherwise, what prevents you from just using beam clamps? Not being critical, just curious.
carpenter? Are you talking about drilling engineered I joists (wood), or steel I beams?
Can you drill metal I-beams ,bar joist's in a manufacturing plant to hang box's ,strap's etc .... Is there a code on this ?
Attention to the OP might help.. don't know... I've drilled (seems like a lot of work) beam clamped and stuck threaded rod between the joists, Tech5, shot a cap. Seems more like what the job spec's will let you do, as opposed to what one would like to do.
oops, thanks. 'carpenter' threw me off.
Our facility has columns & you cannot wield or drill them. Only clamps are allowed. Wielding will make them brittle & drilling holes weakens them, or so say the wise. We also have four 15 ton crains rolling across the top of ours.
In the past I have seen everything including EMT wielded to them.
Not any more.
Not any more.
Welding brackets and other types of support to structural steel use to be a standard practice in all of the high-end industrial jobs I've worked (power plants, steel mills & foundaries, refineries, etc.), but many have gotten away from that practice nowadays, requiring clamps and other "non-invasive" attachment methods. There doesn't seem to be much in the way of factual events backing up the change. I believe it is more of a myth created by structural engineers ;)
I simply ask the customer to have a structural engineer or Architect approve what we intend to do and after this we're covered.
Roger
Roger
i agree, it is always best to get the design prof. involved, that signed & sealed letter takes you off the hook
