jetlag
- Eatonton, Georgia
I had to run a new s e r 100a feeder into an existing 100a inside panel. Who ever installed the inside panel ran all the conductors into the box right thru the knockout holes with out installing and connector clamps. I can use the plastic remodeling bushings than push thru from the inside of the box . But what can I do where they ran about 10 romex wires thru a 2" knockout hole. Id have to cut a big hole in the drywall to pull the wires back out . If I put a pvc adaptor in the opening with a lock nut and plastic insulator could i put the wires back thru . would they need to be stapled before entering the box.
