Computer gear trips ARC faults
WirenutGP
Lamps, drills or tv set plugged into the outlets will work fine fine but if you plug in the computer tower or monitor the ARC breaker will trip after about 10 seconds. Breaker is Sq D QO, any idea what's causing this or how to fix the problem?
Removing the ARC protection is not an option.
thanks
thanks
Problem w/ the computer?
Glad to see you're not going to remove the AFCI.
A friend of mine ran into the same issue I told him I would not remove the AFCI protection ,. they found someone who would. I'd try another breaker ,.. then perhaps even a small sub panel with a different brand AFCI
