ITE? You haven't worked since the 70's?
Siemens only dropped the I-T-E brand in the mid 1990's.
I think they're secure now! Last year Siemens did around $458 billion!!Siemens ITE
I have never seen or heard of this problem. ever.I would have to disagree. I have had CH bus bars flex at the main lugs.
I have never seen or heard of this problem either.A few years ago that was a no brainer, CH Classic was the best all over, then someone got a bright idea to change the bus in the panel, and ever since that change, breakers fall out and loose fit in panel, now we consider it's just another junk product, this is after over 30 years of use.
Doubtful, from normal torque, but if it happened, that would be a warranty issue.Yeah, once I snapped a neutral bar just by tightening the set screw on a wire.:roll:
Let's see..for starters, how are you going to 'make' this breaker trip? By using my 'boom box'?Start with a panel full of breakers, some of them on, and others off. Now trip one out. I dare you to find the tripped breaker in the CH panel without knowing which breaker it was beforehand.
Do the same thing with a QO panel. No problem locating the tripped breaker in a matter of seconds. Even the Homeline breakers go ?-way when tripped.
....What does it really matter if there is a trip indicator window??
The panel label should be clearly marked.
And, one should never just re-set a tripped breaker, without first checking out the circuit, which would require the panel cover to be removed, anyway.
if you had to choose only one brand to use (residential and light commercial) which of the three would you select?
i agree cutler hammer classic is high quality and highly priced. i would use them but at well over $3 for a 15 amp single pole there not for me.
I've seen both QO and CH breakers loose on their bus bars (likely due to loose spring clips, which are a poor design in the first place), so no clear winner there.
The resi stuff that GE makes is garbage.
~Matt
Yeah, but what were their costs?I think they're secure now! Last year Siemens did around $458 billion!!![]()
Okay, but what would you have done if the half-of-the-panel-were-off breakers you found off were QO's and they all showed orange?A panel with breakers that indicate a tripped condition would have been much more desirable in such a scenario.
Anything GE is junk!! I will never buy GE crap again!!
Murray is good for resi, QO or QOB for commercial / industrial.![]()
Main breaker in 200 amp power was too stiff to turn on if someone turned it off couldn't get it back on. I don't have the statistics but remember changing several, the supplier made them good but I had the trip and labor time. At least two I changed out hot where there was a bolt-in meter, don't worry, I was younger then and would not recommend this practice.What kind of problems did you have with Bryant that gave you a bad taste?
Same thing that we ended up doing: Had to remove panel cover, and manually trace out the line for our circuit.Okay, but what would you have done if the half-of-the-panel-were-off breakers you found off were QO's and they all showed orange?![]()
