No one's gonna get hurt with my Folio issues........![]()
Says the guy who uses aluminum ladders.
That are set up properly.
Next time, I'll use a nice conductive steel scaffold if it gives you a warm and fuzzy feeling.
Exactly, when you decide it is OK it is fine, when someone else makes the same types of decisions you find fault with it.
Kind of hypocritical IMPO.
Next time I work on a ceiling fan that's 26' off the floor and it's energized, I'll call you and get an OSHA-approved method.
Sorry, but you sound older than 49....and you sound to polite to be from South Florida....don't tell me you use your turn signal's when your driving too!
That was a typo, I'm 94. What are 'turn signals'?
Green to X0
White to X3
I'm confused. What's up with that?
Edit: maybe that's blue, not white, but then I'd ask where the neutral is? I really should be asking why are you pulling a ground?
It's that light on the left side of your van that flashes when you drive it.
Who does those big cutouts in the building wall to run your conduit through? We usually have to core drill ourselves and use LB's.
