justin59
- loma linda, ca
would over sizing the neutrel help with any of this?
it shouldn't make a difference
hello, i figured this would be a grounding issue! i was talking to a friend who has a recording studio at his house, but can't seem to get rid of the humming and noise interferance from his equiptment. right now i'm scratching my head cause i haven't dealt with much audio stuff before, but am going to check it out next week. can anyone give a suggestion as to what i can do/or look for, that may help?
thanks, bohl1076
balanced cables will have 3 conductors, 1 black, 1 red or white and 1 bare wire. If it is an XLR type connector (the plug end is round with 3 pins in the center) the shield solders into pin 3. you can simply cut the shield where it terminates onto the connector. If it is a TRS type connector (looks like a larger version of a headphone jack) the shield is soldered onto the metal frame of the connector. You do the same thing, cut the shield at that point. when I used to install large sound systems, we always lifted the shields on every line level input. just make sure you don't do it on the microphone input.
Electronics wizzes want to over-ground most of the time. They usually want to drive their own seperate ground rods.
Now that's funny.
They Should, but do they?
ohmhead, have you seen this done, or is this jobsite talk?
I have a hard time believing that they would not be using isolation transformers if needed.
Maybe you just didn't see them being used.
I could see their engineers lifting a ground to find the problem, but not leaving it.
this may be a stupid ?, but would over sizing the neutrel help with any of this?
pin 3 hot was popular on English equipment for a long time.
<snip>
Point is the sound tech geeks at disney or universal have the ability and electronics back ground .
May you should apply for a job there and let them know what there doing wrong because iam not we like there projects its income .
Did you know disney has there own building dept and its own electrical rules & regs .
There a city on there own they do not use your local or county electrical inspectors .
What do you do when you have a insulated tool install a ground on it ?
Relax think about it i think there poeple are highly able and know what there doing .
we did not take ground off they did !
I dont think they use radio shack equipment at Disney or universal studios.
Example orange county convention center does it also the sound crew takes it off during a big show like during a concert you need to ask them why .:roll:
Lee, welcome.
I also do audio, and own a sound company, among the very many things that I do.
We can provide up to 32x8 FOH @7800watts
Plus 12x6 monitor mix with 2000w plus in-ear channels.
Although our monitor board is in for repair, so right now we only provide up to (4) monitor mixes.
But for most, a 16x4 mix is all that is needed and typically 5800w FOH.
The Tutorial link you provided has some good info. But when it gets into the IG receptacles, I'm not sold.
Also, the 'Poorman's Distro' I don't think will help the OP.
He is talking about a home recording studio.
See 520.53(O)(1)
... This usually occurs when over the road tour groups paralell two (out of three) hot legs of their 3 phase 4-wire switchboard onto one hot leg of a single phase service. ...
Awesome! Are you a member of PSW?
As far as the poormans, it works great in noisy clubs. But I see your point, in a quiet home studio, as compared to commercial/industrial settings, it may not fix whatever his problems are, but I can't see how it would hurt to try!
The newest standard is:
XLR Pin 1 is shielded.
Pin 2 is hot
Pin 3 is cold
But you'll find on older equipment, pin 2 and 3 may be reversed hot and cold. (Pin 1 is still shielded.)
Click here for more information: http://www.whiskey-creek.net/pwrdist.html
Lee! I've just clicked who you are!! Excellent!!!
I agree. it is totally not necessary.Coming into this late, it seems...
Can we ditch the "use only one phase" theory, please?
dbuckley said: "The first thing the poor hummy chap should do is to run everything off one outlet, using lots of multiboards."
