- Chapel Hill, NC
- Retired Electrical Contractor
ok lets say I LB it into the house and pipe about 10' to the panel. worse case scenerio what could go wrong, what is UNSAFE about the installation? remember that there is a disconnect about 170' from the LB.
rw
You have to stop thinking n terms of what is unsafe. You need to be thinking what is legal. Many of us pick the ones to worry about. Personally if the use-2 insulation was a rhw/rhh then I don't see why it would be a problem but 338.12 clearly states no seu cable interior. Now one may say it does not forbid USE-2. Tough one to call.
I try yo stay legal because I have found there are many reason I don't understand why a code is written a ceratin way. Simply because I don't get it is not enough to break the rule.
