Is it common to wire three (277V) lighting circuits together to one 3 pole circuit breaker (I guess the three circuits would be run together with the ballast connected to alternating phases)?
If yes and they are electronic ballast should the neutral be three wires or over size? (the above refers to 277V inside fluorescent lighting)
A sort of related question - Is there any reason not to use 480V (one phase) for exterior pole mounted medium base HID lighting?
