The rest of the story... I voted for the larger loosing percentage
Yeah, me to !
Only if you have a nutty inspector.Is this question and answers serious?
INSTALLING THE COVER
1. Remove the cover twistouts.
a. Remove only enough twistouts to match the number of circuit
breakers being installed.
b.Twist out with pliers at the center of the twistout. See Figure 8.
c.Close all unused open spaces in the cover using filler plates
as listed on the cover directory label.
2. Attach the Spanish translation label, if supplied with the load
center, to the rear of the cover. See Figure 9.
3. Identify the branch circuits on the directory label.
4. If the load center is used as service equipment, apply the
?Service Disconnect? label to the part of the cover nearest the
main circuit breaker handle. If the load center is not used as
service equipment, apply the ?Main? label to the part of the cover
nearest the main circuit breaker handle.
5. Install the cover using the screws provided.
VIOLATION! I used my fingers to remove the twistout.
Conflicting instructions^
When the time comes when I am not allowed to make a simple decision like "what kind of screw can I use to secure a panel cover", is the day I hang up my tools. Freakin stupid.
Screws are overrated.
Take away all our screws and we have nothing holding our world together. What we need are better screws.
We used to describe shabby buildings as being held together by termites holding hands.Take away all our screws and we have nothing holding our world together.
IN the poll it addresses machine screws, the question was about metal screws. Big difference. However, the answer is the same NO!! Only a panel cover screw can be used. The difference is that on a panel cover screw the first 1/8 inch or so has no threads to cut through insulation.
“Service Disconnect” label to the part of the cover nearest the
service equipment, apply the “Main” label to the part of the cover
Did anyone notice that the percentages add up to over 100%?
