- NE Nebraska
The only people that can pull a permit are contractors or special license holders for the type of work covered by their special license. Homeowners may file permit and work on their primary residence only. There are no more homeowners working on a new home (some still try) because a couple years ago the State Electrical Division decided that a new home is not a primary residence until it is occupied. There is an owner request for inspection but is is just that, an inspection. If there was an install then the installer needed to meet requirements and pull permit before starting work.From Nebraska State Electrical Act:
81-2106 Plan, lay out, or supervise certain activities; license required; exceptions.
[FONT=Times New Roman,Times New Roman][FONT=Times New Roman,Times New Roman]Except as provided in section 81-2108, 81-2110, or 81-2112, no person shall, for another, plan, lay out, or supervise the installation of wiring, apparatus, or equipment for electrical light, heat, power, and other purposes unless he or she is licensed by the board as a Class B electrical contractor, an electrical contractor, a Class A master electrician, or a Class B master electrician. [/FONT]
[/FONT]
Source
[FONT=Times New Roman,Times New Roman][FONT=Times New Roman,Times New Roman]Laws 1975, LB 525, ? 7; Laws 1978, LB 833, ? 4; R.S.Supp.,1980, ? 81-577; Laws 1993, LB 193, ? 6; Laws 2003, LB 126, ? 5. [/FONT][/FONT]
81-2108 Wiring or installing; license required; exceptions; lending license prohibited.
[FONT=Times New Roman,Times New Roman][FONT=Times New Roman,Times New Roman](1) Except as provided in subsection (2) of this section or in section 81-2110 or 81-2112, no person shall, for another, wire for or install electrical wiring, apparatus, or equipment unless he or she is licensed by the board as a Class B electrical contractor, an electrical contractor, a Class A master electrician, a Class B master electrician, or a fire alarm installer. [/FONT][/FONT][FONT=Times New Roman,Times New Roman]
[FONT=Times New Roman,Times New Roman](2) Except as provided in section 81-2106, 81-2110, or 81-2112, no person shall wire for or install electrical wiring, apparatus, or equipment or supervise an apprentice electrician unless such person is licensed as a Class B journeyman electrician, a journeyman electrician, a residential journeyman electrician, or a fire alarm installer and is employed by a Class B electrical contractor, an electrical contractor, a Class A master electrician, a Class B master electrician, or a fire alarm installer. [/FONT]
[FONT=Times New Roman,Times New Roman]For purposes of this section, the holder of a fire alarm installer license shall only supervise those apprentices engaged in the installation of fire alarm equipment and apparatus operating at fifty volts or less. [/FONT]
[FONT=Times New Roman,Times New Roman](3) No person licensed under the State Electrical Act may lend his or her license to any person or knowingly permit the use of such license by another. [/FONT]
[/FONT]
Source
[FONT=Times New Roman,Times New Roman][FONT=Times New Roman,Times New Roman]Laws 1975, LB 525, ? 9; Laws 1978, LB 833, ? 6; R.S.Supp.,1980, ? 81-579; Laws 1982, LB 605, ? 1; Laws 1993, LB 193, ? 8; Laws 2003, LB 126, ? 7; Laws 2004, LB 914, ? 2. [/FONT][/FONT]
81-2110 Installer; license; rights and privileges.
[FONT=Times New Roman,Times New Roman][FONT=Times New Roman,Times New Roman]Any person holding an installer license may lay out and install electrical wiring, apparatus, and equipment for major electrical home appliances on the load side of the main service in any municipality having a population of less than one hundred thousand inhabitants. [/FONT]
[FONT=Times New Roman,Times New Roman]Source [/FONT]
[FONT=Times New Roman,Times New Roman][FONT=Times New Roman,Times New Roman][FONT=Times New Roman,Times New Roman]Laws 1975, LB 525, ? 11; R.S.1943, (1976), ? 81-581; Laws 1993, LB 193, ? 10. [/FONT][/FONT]
[/FONT][/FONT]
81-2112 Special electrician license; licensee; rights and privileges; qualifications.
[FONT=Times New Roman,Times New Roman][FONT=Times New Roman,Times New Roman]The board shall by rule or regulation provide for the issuance of special electrician licenses empowering the licensee to engage in a limited class or classes of electrical work, which class or classes shall be specified on the license. Each licensee shall have experience, acceptable to the board, in each such limited class of work for which he is licensed. [/FONT]
[FONT=Times New Roman,Times New Roman][FONT=Times New Roman,Times New Roman][FONT=Times New Roman,Times New Roman]Laws 1975, LB 525, ? 13; R.S.1943, (1976), ? 81-583. [/FONT][/FONT]
[/FONT][/FONT]
Agricultural wiring is exempt from inspection but not from the other laws (makes a lot of sense doesn't it?) State lawmakers will be the ones that allow this to change and it probably will not in a state where Ag is the largest industry. Problem is farms and facilities are getting larger and wiring is more complicated and is no longer much different than other facilities. I do regular work on a dairy farm that has 800 amp 480 volt service. Big change from old daries that only had 100 amp single phase services.
