curt swartz
Electrical Contractor - San Jose, CA
- San Jose, CA
- Electrical Contractor
I had an interesting inspection today for a new residential service panel. This was for a Square D 200 amp combination service entrance device (load center and meter socket in one box). The inspector asked where the oxide inhibiting compound was on my service conductors. I responded that my service conductors were copper and even if they were aluminum no compound was required unless instruction and listing for the lugs require it. She replied that at a recent seminar a rep from Alcan stated that all aluminum lugs must have an oxide inhibiting compound unless the manufacture of the lug provides instructions stating that it is not necessary. She said it did not mater if the conductors were copper or aluminum the issue is the aluminum lug. I tried to explain this makes no sense since the aluminum lugs are plated during the manufacturing process and are not raw aluminum. If they were raw aluminum the lugs would already be oxidized from being exposed to the air for period of time between manufacturing and actually having wires terminated in them.
I mentioned that I would contact Square D about this issue but she stated that since Square D doesn't manufacture the lugs I would need to contact the lug manufacture. Since these lugs are factory installed as part of a listed device as far as I concerned Square D is responsible for any instructions relating to these lugs. I should not have to figure out who manufactures every part of a listed assembly and contact each of these manufactures for instructions and listing info.
I plan on contacting Alcan to see why they spreading this information.
