Is this safe enough?
readydave8
re member
Clarkesville, Georgia
electrician
While installing an exterior receptacle today I realized it was arc fault protected, ground fault protected, tamper resistant and weather resistant.
Any advice on how I could make this installation safer?
ceb58
Raeford, NC
Don't send power to it. But you did forget the in-use cover.
growler
Atlanta,GA
I don't know, did you put a bollard in front of it just in case the homeowner comes home drunk and wants to drive around the yard?
Cow
Eastern Oregon
Maybe install an arc flash sticker above it?:cool:
Install a redundant ground like required in health care facilities, maybe isolation transformer also.
oh yeah, don't forget to drive a ground rod near the receptacle and connect it to the receptacle.
CopperTone
MetroWest, MA
enclose a room around it and be sure to have enough working space clearance in front of the receptacle and have the required egress with crash bars on the doors
hillbilly1
North Georgia mountains
Owner/electrical contractor
I think the in-use covers almost detract from the safety since they get knocked off (broken) so often.
Going a little off topic:grin:, But I use these on the higher end houses, not very expensive either. For some reason though the supply house will not stock them. I always have to order a case of them at a time.http://www.aifittings.com/whnew73.htm
wireguru
your installation is quite unsafe. The receptacle should be supplied with MI cable, fed from a shunt trip breaker. The in use cover needs a cover interlock switch, so the shunt trip breaker is tripped when the in use cover is opened. The control wiring for the shunt trip circuit should have a 2hr rating.
