The job I inspected has a 2500 amp 480v buss fed by a separate switchboard at each end (no "tie" breaker..no break in the buss). Each Powertran Switchboard is being fed from separate 15kv feeders.
I had immediate concern about the buss not being properly protected and more so concerning the possibility of the 15kv feed to switchboard "A" being turned off and then back-fed from the power supplied to "B", a situation I have seen prevented by the kirk-key set up.
In this case I am advised by the engineer that a "new and improved" method is being used, a Bassler Reverse Power Relay" which prevents such back feeds.
My "old school" mind is not comfortable with the system without the manual control of a tie breaker.
Is anyone here familiar with the BRPR and find my concerns unwarranted.
