criss
 - new york city
Am i allowed to run 4- 3/0 and #6 ground wire thru a 2" emt lb???
Where would i find in nec about lb rules
The only way you can get around the sizing rule in 314.28(A)(2) is if the maximum size and number of conductors is marked on the LB. 314.28(A)(3). This is a rule that is often violated as many assume that the wire fill for a conduit body is the same as the conduit. This is not true for conductors that are #4 and larger.Interesting that it is marked on the emt LB's etc, but I have never seen it on a 2" PVC LB. I will have to check more closely.![]()
I actually looked inside the 2" PVC LB at the supply company and it stated 3-4/0 wires. I guess that means I could put 2- 3/0 and 1- 1/0 with #6 ground. This is what I usually do....
3- 4/0 assuming THHN is equal to .9711 sq. in.
2- 3/0, 1- 1/0 and #6 is equal to .7720 sq. in.
Not sure how to convert since insulation size is not mentioned. Perhaps the insulation would not be needed for the calculation. That seems odd- why not just state max size 4/0 wire and then give a cu.in size allowable.
Beside the max size, there is also a max number. You can't put 4 4/0 in the aforementioned LB.
There is also bend radius to consider. A single conductor of .940 (900 kcmil) would be tough to install in a 2 inch PVC lb without damage, if not impossible.
Dennis your method may make sense but the stamping states a max of three conductors with a max size of 4/0. There was another thread on this topic that You may want to take a look at. If all your conductors are under #4 than you are not limited to 3 conductors.
Then that fitting cannot be used with conductors #4 and larger unless the spacing between the conduit entries meet the requirements in 314.28(A)(2)....
Edit-- I just found an LR in the basement that states vol. 68.4 cu. in. no conductor size....
