I don't use a torque driver, but I do make sure I 'finesse' a screw 'tight enough' that it's going to stay tight and cool for a long time without damaging the screw or wire.
When I was a young apprentice (1958), I worked with an Italian man.
We had contest one day about who could twist the heads of the most 1" PHSMS.
We stood on a ladder and put them into an overhead joist.   Not too many, tough!
This was not 'finesse', but I understand you mean an extra 1/4 turn.
Have you noticed that you can 'apply' more torque with a flat blade,
than with a phillips blade ?
I am sure you have noticed that the Robertson (Square) point is pretty good for applying max torque, and sustains contact even if off angled slightly.
Have you measured the available torque from your best hand ?
I had Amish friends when I was young, who had hands the size of my feet,
so I am not bragging much when I say that I was able to produce a 40 inch-pound torque on a measuring machine (when I was younger).   That torque is about 3 times the recommended for an 8-32 machine screw used on the recepticals.
Well, I thought that was interesting.  A built-in torque estimating gauge.
It's the middle of the night. Got to stop this chatter.
