mengelman
- East Texas
Are stainless romex staples made? Any idea where I can find some?
Thanks
Mike
			Thanks
Mike
Why do you need stainless steel staples?
Chris
Chris
Under a boat dock.
Isn't that defined as a 'wet location'?:-?
I would call it a wet location. Thats why I want to use SS and UF. Is there a problem with this.
Sorry should have said UF staples!
Check out 555.15(B).
Ok, I'm busted. What is the advantage of having an insulated grounding conductor?
Added protection from corrosion.
Chris
not buying that. I have worked around these boat houses for years. Never have seen any corrosion where the wires are striped to attach to the devices. Most of the boat houses on this lake are wired in romex buy the way. Like a lot of lake properties there are a lot of hacks and homeowners working.
The provisions of 555.15(B) require an insulated equipment grounding conductor that ensures a high-integrity path for ground-fault current. Because of the corrosive conditions in marinas and boatyards, metal raceways are not permitted to serve as the sole equipment grounding conductor.
Here is a quote from the 2008 NEC Handbook.
Chris
there is an exception for dwellings, its allowed..
