- Illinois
- retired electrician
You might cite OSHA violation as the reason. OSHA requires insulation or isolation to be used as protection from equipment that operates with surface temperate high enough to cause that burn. However there is no specific rule that requires this, but OSHA has said in this document that they can issue citations for hot surfaces.
