iwirehouses
I am putting a 100 amp service in a garage. They are going to drywall the garage so I am going to flush mount the panel. Whats the best way to flush mount a panel, then use 2" pvc out and into the ground. I'd like to come out the back with a TA to LB but that would leave me with a several inch gap between the vinyl siding and pipe. If I came from the bottom of the panel with a back to back LB to get inside/outside, Then I would have to leave the indoor LB cover accessible (probably have them build a cabinet around the panel and LB rather then cut drywall around the LB) and I would still be an inch or more off the vinyl siding. I've done it this way with a nice runner between the vinyl siding and pipe, but wondering if theres a better way.
