Hendrix
- New England
To me it makes perfect sence, if replacing a 3 wire receptacle, to replace it with a TR receptacle. What do you guys think?
I think you are suppose toreplace with TR as of 2008 NEC. I don't even stock non TR recep.To me it makes perfect sence, if replacing a 3 wire receptacle, to replace it with a TR receptacle. What do you guys think?
Or simply pull the plate off.I guess it's time to make up a small extension cord to put in your tool bag.
Yeah, I suppose I'll have to do something!I did come up with a new name for the TR receptacles though. (I'll try to keep it G-rated so it doesn't get deleted) I now call them "DP receptacles!":grin:
Took me a second but that's pretty funny.![]()
Some inspectors are saying, just replace what you remove with the same.OK, what happened.![]()
That would be correct. It should come down to what was code when the permit was issued.
I would say the receptacle is new and should meet current code.![]()
I would say that it should be interpreted as AFCI is.![]()
AFCI may be different since you can change a recep and not have to add AFCI to the circuit. But I believe if you replace a recep. in a bathroom that was not GFCI protected previously that you have to use a GFCI as a replacement. Same for TR as I stated in Post #2
I agree and I thought I explained all that above.Slippery slope here, and no NEC text to back it up that I know of.
