I agree and I thought I explained all that above.![]()
Memory is the second thing to go, Dennis......
Memory is the second thing to go, Dennis......![]()
Some inspectors are saying, just replace what you remove with the same.
OK, my mind is as far in the gutter as anyone on the planet, but I still don't get it :roll:Going back to my problem with testing from ground to neutral or using my "sniffer" on TR (DP:grinreceptacles, I thought of a simple solution that I will toss into my tool bag:
As for hardworkingstiff and all others who don't understand "DP," you are not dumb. In fact, this says good things about you...your minds are not in the gutter like some of ours are!
Let's just say...sort of rhymes with "bubble denigration!":grin:
Unfortunately you will not find this written anywhere. It comes down to interpretation. You have a point about AFCI however it has been widely accepted that you do not need to involve AFCI if the circuit is not extended.
In terms of non grounded being replaced with non grounded receptacles-- that is explicitly allowed in art. 406.3(D)(3)(a)
No one has thought to define when AFCI and TR's should be used. IMO, the cost of a TR is insignificant esp. if you are replacing just a few. My suppliers don't even stock non TR recep. unless they are 20 amp.
OOPS! I tried to post a picture of my new diagnostic tool, but failed! Here's a link instead:
http://www.hardwarestore.com/pop-print/larger-image.aspx?prodNo=409&multiple=2
Wow, what will they think of next? Gotta get me one of those.
Here is the change. Article from iaei.orgAll this debate will be over under the 11 code IIRC. Replace a receptacle that would require AFCI protection and it will need something that hasn't even hit the market yet. Yes, the elusive AFCI receptacle.
ARTICLE 406 Receptacles, Cord Connectors, and Attachment Plugs (Caps)
New: 406.4(D)(4) Replacements ? Arc-Fault Circuit Interrupters
This proposal would require AFCI protection in existing locations where a replacement receptacle is installed in a location where AFCI protection would be required in new installations. The existing requirement in 406.3(D)(2) requires GFCI-protected receptacles where replacements are installed at receptacle outlets that are required to be so protected elsewhere in the NEC. The benefits of AFCI protection have been well substantiated over the last few NEC code cycles. There is no practical reason to limit the level of safety provided by an AFCI to new homes only. This proposal will provide AFCI protection for older homes by requiring the gradual replacement of non-AFCI-protected receptacles with new AFCI-protected ones.
These same receptacle replacement requirements have been proposed for tamper-resistant receptacles at 406.4(D)(5) and for weather-resistant receptacles at 406.4(D)(6).
