Hendrix
- New England
To me it makes perfect sence, if replacing a 3 wire receptacle, to replace it with a TR receptacle. What do you guys think?
I think you are suppose toreplace with TR as of 2008 NEC. I don't even stock non TR recep.To me it makes perfect sence, if replacing a 3 wire receptacle, to replace it with a TR receptacle. What do you guys think?
Or simply pull the plate off.I guess it's time to make up a small extension cord to put in your tool bag.
Yeah, I suppose I'll have to do something! I did come up with a new name for the TR receptacles though. (I'll try to keep it G-rated so it doesn't get deleted) I now call them "DP receptacles!":grin:
Took me a second but that's pretty funny.
Some inspectors are saying, just replace what you remove with the same.OK, what happened.
That would be correct. It should come down to what was code when the permit was issued.
I would say the receptacle is new and should meet current code.
I would say that it should be interpreted as AFCI is.
AFCI may be different since you can change a recep and not have to add AFCI to the circuit. But I believe if you replace a recep. in a bathroom that was not GFCI protected previously that you have to use a GFCI as a replacement. Same for TR as I stated in Post #2
I agree and I thought I explained all that above.Slippery slope here, and no NEC text to back it up that I know of.
