perry vogler
- Wildwood Florida
stranded wire.
stranded wire.
When terminating stranded wire to a device you must do the UL listed and labled thing. So buy the device that is rated for stranded wire. The fork terminal also has it problem. If your in a pintch strip 1.5 inches from the end, strip .5 inches. be sure to keep the insulation on the end of the wire, now twist the bared spot ccw tightly but do not damage the wire. wrap around the screw and hold with your linemens plyers until the screw is firmly tightened. Than wrap three wrap of electrical tape, (relax and cut tape at the end so the tape stays and doesn't unravel). Lot of extra time is waisted when you don't buy a device sutiable for the job. PV
stranded wire.
