jetlag
- Eatonton, Georgia
If you use the first cable hole nearest the stud on a 3.5 " nail on or other box the cable coming out the knock out violates the 1.25 " distance from the edge of the stud. Is this a code violation. To be safe if possible I use only the second or more cable punch out. that moves the cable to the right or left away from the stud the required distance where it doesnt matter if the cable is 1 " or less from the back side of the dry wall. The cable can be pulled back over the top of the box to get the required distance before going to the stud to staple. Is this a necessary thing to do or is there an exception for the deep boxes at the first punch out hole.
