jetlag
- Eatonton, Georgia
I have customer with a hot tub that has the factory installed GFCI in the tub . It is not one that serves as as an overcurrent breaker. It reads the two hot lines like a clamp on amprobe would. If they dont equal it trips a small breaker that breakes the primary to a 240 volt relay which stops the current.. Ok the tub will run a while and the breaker trips . since it doesnt break for an overload and the breaker in the main panel doesnt trip i am assuming there is a small ground fault leak some where. problem is how do i locate it . it has pumps , lights , hearters ect . I plan to check amp draw on every thing but not expecting to find a problem there since that gfci is more like a gfci receptacle , it reads the fault but not over current
