What is the power of an incandescent lamp at 200v 5A?
  • Total voters
    75
While the ten minutes was arbitrary, there was a discussion on some forum a while back by somebody about energy metered over an interval period with the load being off part of the time. It should have been clear that that was within the realm of possibilities. :grin:
Oh, okay.
One million dollars to anyone who can tell me how many kwh my house used last year, without contacting my power company.
My answer related to the original question.
In the subsequent unrelated post about the 4.5kW for 30 minutes, it does mention steady state. One might reasonable construe that as being steady state for the 30 minutes. Otherwise, it is a meaningless question.
That was my point.
And that was the relevant point:
... and then claim that the answer is not accurate because the values you have provided may not be appropriate for the problem at hand.???
If you intended to pose a problem involving a circuit, would you not provide values suitable for that circuit?
If it does not compute, it is because you have provided inaccurate information.... and it's supposed to be some sort of riddle or something because it was answered using values you provided?
Appears to conflict with it being steady state.
OK Mivey can you guess my KWH?
Oil heat, electric range, dryer, AC, small single family home. Two preteens that leave stuff on. :grin:
I'll go with Roger and Larry since we don't know the resistance coeifficient which is usually positive and from my experience well 200 volts x 5 amps. still equals 1Kw.
It might be extra bright or dim but ------ Power = Volts x Amps
I go with A :)
I think they should make electric meters that read out directly in dollars, real-time and cumulatively, with an indoor remote display.
Nah, they'd never do it. It would be like having a clock in a bar.
100806-0715 EST
Besoeker:
In our case the power company owns the gas company. There previously were two different companies Detroit Edison and Michigan Consolidated Gas Co., then Detroit Edison bought Michcon and now the company is DTE Energy. On the western side of the state Consumers Power is both electric and gas.
