LarryFine
- Henrico County, VA
- Electrical Contractor
No, but that's the result every time I look at an electric bill. :roll:Do you pay your power company for gas?
No need to worry yet; I'll run about 33k/yr with some months over 4k.Ouch, and I thought my bill was already high.
From 6/9 to 5/10 12,569 kWh.
As little as 25 per day (Nov) up to 50 per day. (Aug)
I did at my previous location. I also paid for street lights on my water bill (a carry-over from the days when the water system had the only available billing system). Many utilities are multi-service providers.Do you pay your power company for gas?
Then he might not be as profligate as your figures suggested.The point for Larry was that the usage I quoted might be high since he does not use electric heat strips.
I gave him extra because he's the man!Then he might not be as profligate as your figures suggested.
Indeed. A Fine man (so maybe he works for some sort of law enforcement agency, or a librarian....?)I gave him extra because he's the man!
The Man SongI gave him extra because he's the man!
Oh, Lord, it's getting deep in here. :roll:Indeed. A Fine man (so maybe he works for some sort of law enforcement agency, or a librarian....?)
Reasonable and accurate.In post #61 he mentioned power company so it would have been reasonable to assume that his question related to electrical energy. His subsequent post #81 confirmed that his power company didn't charge for gas.
I really have no idea. I've never tallied it up. That sounds too much like work.That's the basis on which I asked you if you thought Larry was profligate when you guessed at 13,500 kWh.
But if he bought gas from a power company, gas company, or the yard-broom man, the company he paid does not impact the kWh used. The only impact on kWh was whether or not he had gas appliances instead of being total electric.In post #61 he mentioned power company so it would have been reasonable to assume that his question related to electrical energy. His subsequent post #81 confirmed that his power company didn't charge for gas. I think this is the normal situation - I have quite a few friends and relatives in the USA and those who use gas pay for it separately.
In 2008, the average residential U.S. customer used 10,913 kWhAverage electrical energy consumption per household is about 4,700 kWh in UK and about double that in USA. Say 9,000 kWh.
Really it was just a swing based on the reported sales. The annual residential use in Virginia is 14,071 kWh. The biggest (Virginia Electric) has an average of 13,877. There were 34 utilities and the mean (average of the two in the middle) was 13,626. 13,500 seemed like a nice round number for Larry.That's the basis on which I asked you if you thought Larry was profligate when you guessed at 13,500 kWh.
Add: The Virginia averages for different utilities ranged from 9,720 kWh/yr/residence (A & N Electric Coop) to 23,301 kWh/yr/residence (Town of Wakefield).
You made my point.In 2008, the average residential U.S. customer used 10,913 kWh
Don't your librarians fine you for overdue books?Oh, Lord, it's getting deep in here. :roll:grin
But, a cop? Never!
Librarian? If she's cute.
Considering (among other things) that:You made my point.
It's a fair point although I didn't actually make such a comparison.Considering (among other things) that:
1) The US has the wide ranging areas (like from Alaska to Florida), and comparing the average across such a broad area is probably meaningless.
I didn't compare them. I had done some previous searching on this for a different topic and the numbers that came up indicated that the US consumption was about twice that of UK. I used that to jump to the 9,000 kWh. It was evidently an underestimation.2) Comparing the US to the UK makes the area much broader and much less meaningful.
But you included gas. See post #71.3) The average usage in Larry's state is close to what I quoted for Larry.
I know. I don't use words that I don't know the meaning of.4) Profligate mean recklessly wasteful.
Nor prudent.5) Being average in your local area is not a good indicator of being profligate.
Nor prudent.6) Being less than 24% above a national average that covers a broad expanse of territory, lifestyles, and customs is not a good indicator of being profligate.
Quite right.7) Being below the average for your local area is not a good indicator of being profligate.
If your point was that your basis for your question of profligacy was conjectural, then I made your point. :grin:
No, I did not include gas in my estimate. I don't know what the gas/electric mixture is in Virginia and did not bother to look. Nor did I make a load calculation based on total electric vs a gas/electric mix.But you included gas. See post #71.
Of course you do. I was just summarizing.I know. I don't use words that I don't know the meaning of.
Right you are.Quite right.
It doesn't tell you anything more than below average. It could be anything from an average family being parsimonious to a single occupancy bachelor pad with no care being given to economy of use.
An exaggeration on my part for effect only.It was a little more than just conjecture, but let that pass.
Maybe you need to tighten up on your research. While we probably make the top 7% or so, we are not the top user per capita.USA uses more energy per capita than any other country.
Of that there is no doubt.The economy has supported a lifestyle that others envy.
What is the power of an incandescent lamp at 200v 5A?
I got nowhere else to go! I got nowhere else to g... I got nothin' else. :grin:Enough to power at least 95 posts.![]()
You're an officer and a gentleman.I got nowhere else to go! I got nowhere else to g... I got nothin' else. :grin:
100802-2046 EST
realolman:
For a complex waveform represented by a mathematical equation one would use calculus to calculate the RMS value.
Correct. I didn't take account of the relatively small populations of the Scandinavian countries.Maybe you need to tighten up on your research. While we probably make the top 7% or so, we are not the top user per capita.
