Rewire
- Lake of the Ozarks
Good. Now dampen it. Drive a metal staple at that location and try again. You will not find every problem. Just most of the ones that will give you grief.
As a side note, I set a torch to the wire and tested it and the reading changed but after it cooled the reading was the same as the original I then completely burned off the coating allowed it to cool and the reading was the same as the original.
IMO using a megger to determine the safety of a circuit is limited and could be accomplished with a simple continuity tester.
